oil leakage.
Old Feb 6, 2009 | 09:38 PM
bobby86's Avatar
Default oil leakage.
Im having a problem with my oil filter. I just did an oil change, now the oil leaks out from the back by the oil filter. The filter looks crooked and when running the oil mist from it, when off it just leaks. Ive replace the filter 3times now and have no clue what to do. can anyone help me out.
Old Feb 7, 2009 | 04:11 AM
welcome to the forum. with the filter off, check to see if the center screw on shaft is secure. the filter you said you replaced, is 3 different filters or the same one?
Old Feb 7, 2009 | 02:30 PM
bobby86's Avatar
Default oil leakage
they are 3 different oil filters. How do i check if it is secure?
