power passenger & back windows not working.
Old 10-22-2011 | 07:53 AM
dkm2's Avatar
Default power passenger & back windows not working.
Help, please!! I have a 2007 Honda Accord in excellent condition. A week ago I noticed that the passenger and back windows are not working. I tried the on/off switch on the driver door controls, as well as the individual doors themselves. Still don't work. I recently had some repairs done on the driver & left passenger door where they had to remove the doors' outer skins. Upon leaving the shop, the windows were working, but I'm wondering if it may have been a delayed damage (?).
Can anyone share some possible things I can check or have any ideas what the problem may be?
Old 10-23-2011 | 10:31 PM
welcome to the forum. Not sure how extensive the repair on the door skin took, but it is possible that the connectors may be loose to the regulator that opes and closes your window. take the inside cover off and check the wiring to see if they are hooked up and or there is power to the regulator.
Old 10-24-2011 | 10:59 AM
If once you have the panels off and the connectors are secure,
Use a digital voltage meter to test regulator power before completely removing it. A reading of less than 12 means you have a wiring or switch problem. Recheck the fuses and switches. A reading of 12 means your wiring and switches are getting power to the motor, so the motor is inoperative for another reason.
Old 10-25-2011 | 02:17 PM
dkm2's Avatar
Thank you for this information, bucwheat & acmech52! I'll have to take it to someone to check out these suggestions. I'll post my findings
Old 10-25-2011 | 03:08 PM
Please do it helps with other members having the same issues.
Old 10-31-2011 | 07:21 AM
Derek_Miller's Avatar
Check the battery and the connections.
VicoDrive
07-07-2014 12:23 PM
kiddro1
08-05-2013 09:58 AM
skifreak
10-18-2010 05:09 PM
s4325
08-10-2010 12:56 PM
micmoor
07-13-2009 09:53 AM
