power passenger & back windows not working.
Old Oct 22, 2011 | 06:53 AM
dkm2's Avatar
Default power passenger & back windows not working.
Help, please!! I have a 2007 Honda Accord in excellent condition. A week ago I noticed that the passenger and back windows are not working. I tried the on/off switch on the driver door controls, as well as the individual doors themselves. Still don't work. I recently had some repairs done on the driver & left passenger door where they had to remove the doors' outer skins. Upon leaving the shop, the windows were working, but I'm wondering if it may have been a delayed damage (?).
Can anyone share some possible things I can check or have any ideas what the problem may be?
Old Oct 23, 2011 | 09:31 PM
welcome to the forum. Not sure how extensive the repair on the door skin took, but it is possible that the connectors may be loose to the regulator that opes and closes your window. take the inside cover off and check the wiring to see if they are hooked up and or there is power to the regulator.
Old Oct 24, 2011 | 09:59 AM
If once you have the panels off and the connectors are secure,
Use a digital voltage meter to test regulator power before completely removing it. A reading of less than 12 means you have a wiring or switch problem. Recheck the fuses and switches. A reading of 12 means your wiring and switches are getting power to the motor, so the motor is inoperative for another reason.
Old Oct 25, 2011 | 01:17 PM
dkm2's Avatar
Thank you for this information, bucwheat & acmech52! I'll have to take it to someone to check out these suggestions. I'll post my findings
Old Oct 25, 2011 | 02:08 PM
Please do it helps with other members having the same issues.
Old Oct 31, 2011 | 06:21 AM
Derek_Miller's Avatar
Check the battery and the connections.
VicoDrive
Jul 7, 2014 11:23 AM
kiddro1
Aug 5, 2013 08:58 AM
skifreak
Oct 18, 2010 04:09 PM
s4325
Aug 10, 2010 11:56 AM
micmoor
Jul 13, 2009 08:53 AM
