weird news
Old Nov 5, 2008 | 05:19 AM
civic2017's Avatar
Default weird news
i have a 97 coupe and just got done doing the axels but now i heard like a creaking noise every now and then when i take off or stop. o think it is my rotors cause they are a little worn. what do you think?
Old Nov 5, 2008 | 06:17 AM
Default RE: weird news
if the rotors were making a creaking noise before you changed your half shafts, then yes possible rotor. Did you use rebuilt half shafts or factory new? If rebuilts, it may be your shafts making the creaking noise. Rotors and pads normal noise is squeeky type of noise or scraping.
Old Nov 6, 2008 | 05:27 AM
civic2017's Avatar
i used new axels but it wasnt making the noise before i did the axels it was only making the clicking noise which i why i changed them to begin with. i know my springs and struts are bad but it sounds like some thing need to be greased.
Old Nov 6, 2008 | 06:22 AM
if you have run your car a few days, by now the half shafts should be quiet. Before looking at the half shafts, try lubing any rubbing part, bushings, springs, with wd-40. avoid getting any on the brake rotor or pads. there might be metal to metal or rubber bushing making that sound.
Old Nov 9, 2008 | 08:44 AM
civic2017's Avatar
yea i already did that i just think its my springs and strut's i guess i will buy myself a coil over kit for xmas. do you have any idea on how to fix the dome light to light up when i open the door it only works when i move the button to on but when i set it to light when i open the door it doesnt work i read somewhere that that tends to happen when you instal a head unit but didnt tell me how to make it work again.
Old Nov 10, 2008 | 08:52 PM
sounds like the light switch is bad. Hope you have a good back, the coil over is a hard ride, also you may have to get a camber kit to keep the front tiresfrom wearing out in 10k miles.
Old Nov 11, 2008 | 05:26 AM
civic2017's Avatar
well i am going to go with the skunk 2 adjustable suspension kit i heard a few good things about this item why got anything better trying to stay in the 700 dollar range
Nov 21, 2014 06:29 AM
alanhkc
Nov 20, 2014 09:38 AM
gazoll
Jul 25, 2013 01:32 PM
Modball Team
May 12, 2011 08:26 AM
ALLm0t0r
Nov 18, 2006 01:57 AM
