windsheild water spraying problem.......
Old 10-15-2009 | 09:12 PM
yrk's Avatar
yrk
Default windsheild water spraying problem.......
My 1995 honda accord windsheild water spraying sometimes don't work. It work sometimes but it won't spray out often. I already put water in it but it only come out once a while. Any help or tips what cause why water not coming out. I check the tube nothing is blocking.
Old 10-16-2009 | 12:02 AM
91haydenSI's Avatar
there is a pump attached to the winshield wiper fluid resivoir.. it may be starting to go bad or out.. it could also be your sprayer nozzles.. detach the tubes from the nozzles and try spraying them. if the stream is still weak then its the pump.. if not its the nozzles
civiclover
07-20-2015 10:32 PM
86_accord2.0
08-01-2007 05:50 PM
FLACHUSNRET
05-28-2006 01:42 AM
FLACHUSNRET
05-28-2006 01:36 AM
FLACHUSNRET
05-28-2006 01:06 AM
Quick Reply: windsheild water spraying problem.......
