BF 9.9 with new impeller runs but won't pump water?
Old Sep 10, 2022 | 08:08 PM
Autom8r's Avatar
Question BF 9.9 with new impeller runs but won't pump water?
I just installed a new raw water pump impeller on my 2006 9.9 engine and it doesn't **** out any water after running a minute or so. Any ideas out there in Honda clamp-on land? There are other problems to address once this is sorted out.
Thanks!
Dave
Old Sep 28, 2022 | 01:09 PM
deuxgrenouilles's Avatar
Are you running it on muffs, or in a test tank? With low water pressure, the muffs might not be pushing enough water. Sometimes the outlet on the tell tale can become blocked by debris or salt crystals. I use a bit of weed whacker string to gently ream it out to get the water flowing. There is also the possibility that the impeller wheel was installed with the fins pointing the wrong direction...
Old Oct 7, 2022 | 10:42 AM
Autom8r's Avatar
All fixed now. I didn't have the upper and lower unit tubes lined up. I put a skinny white coat hanger with the bottom end bent over to prevent it from getting in the impeller housing and had a pal guide it in while I handled the gearcase. I left the skinny coat hanger in. No problem.
BTW, I had it in a 100 gallon water tank.
Thanks!
Dave
Arliev7717
Jun 15, 2021 10:57 PM
Stephen Hicks
Jun 1, 2020 07:34 PM
dandingo1974
Jan 16, 2020 09:43 AM
91accordf22a
May 28, 2006 09:17 PM
