dog clutch replacement in the lower unit
Old Jan 5, 2020 | 07:53 PM
randombaptist's Avatar
Default dog clutch replacement in the lower unit
I have a 50 HP outboard that won't go into reverse. My research leads me to the dog clutch. I have started disassembly, but I am hoping someone can confirm my next steps. I have removed the threaded retainer and washer behind it and next out is the carrier where the water seals are located. Do I use a puller to remove it? Should I be able to pull the propeller shaft out after that, leaving the forward gear and the pinion on the drive shaft in place? Any help is appreciated!
Old Nov 29, 2023 | 09:53 PM
xiong2moua's Avatar
Default Clutch Dog
Hi, where you able to get to the clutch dog?
Swinedog
Jan 3, 2019 08:54 PM
Honda4dummies
May 2, 2010 02:52 AM
gobabygo95
Apr 12, 2010 09:35 PM
herecometheazn
Sep 7, 2007 02:13 AM
nokiakiller
Jul 29, 2007 09:28 PM
