four stroke outboards
Old 02-05-2007, 01:20 PM
bushfollower's Avatar
Default four stroke outboards
i have 2 four stroke outboards 150s that need the 20 hr sevc. im not sure ho to take care of the gear oil that needs to be changed. can anyone help please.
[/align]
Old 02-05-2007, 02:05 PM
Default RE: four stroke outboards
I just purchased a Honda 115 4 stroke ( I believe they are similar )and have not done this myself but have read up on it. There are two flat head screws that are on the left side of the prop looking forward from behind OB.You will need a large flat head scew driver.The fill is above the prop and the drain is below or toward bottom of lower unit.First remove the fill screw above.This will prevent a vacuum from maintaining old fluid.The bottom one drains old fluid out so that needs to be pulled next .Drain old fluid.Afterdrained, fill but make sure you first replace drain screw(bottom)first and then put in new fluid .Then replace thefill screw(top) when fluid is at that level.The type of oil can be derived from Honda's web page. Hope this helps
Old 12-09-2007, 05:22 PM
Deleted User's Avatar
Banned
Default [Deleted]
[Deleted by Admins]
handsome_pete
09-22-2009 02:43 AM
morrisgunn
09-08-2009 05:21 PM
bushfollower
12-09-2007 05:22 PM
Quick Reply: four stroke outboards
