Honda 9.9 Charging System
Old May 1, 2006 | 02:54 PM
Nikkilara's Avatar
Default Honda 9.9 Charging System
Hello,
I purchased a Honda 9.9 four stroke used last year. The charging system does not work.
I measured the AC voltage coming from the Charge Coil to be between 8 volts AC and 35 Volts AC, depending on engine speed.
I measure zero volts DC coming fromthe Regulator Rectifier. Becasue I measured zero volts from the Regulator, I figured this must be the problem. So I purchased a new one. I still have the same problem.
Am I doing something wrong?
Can anyone explain to me how the charging system should work? What voltage should I see from the charge coil? Is my new Regulator rectifer bad?
Thanks,
Steve
Old May 4, 2006 | 11:17 AM
Nikkilara's Avatar
Default RE: Honda 9.9 Charging System
I received a reply back from Honda.
The coil should be outputing between 200 and 300 Vac.
So it looks like a bad coil.
Steve
Old May 8, 2006 | 06:33 PM
Nikkilara's Avatar
The problem is Solved!!
The regulator has to be connected to a battery.
I was trying to take measurements from these various parts, when they were not connected.
The charging system only works when the out-put is connected to battery. There should be some reference to this in the manual.
Thanks,
Old Aug 22, 2006 | 03:53 AM
bhu7946's Avatar
my honda accord 91 previously having a problem is my power distribution not so good...then i went to change a new wan...i run for 6 days..it good...then the problem come again in the 7 days..i cant start at all...my fius broken...when i put a new wan it same aso...i duno whether is i change the power distribution pressure high cause the fius broke or not..does anyone exsperience about it?
Kmontgomeryinc
Aug 17, 2015 05:45 PM
soberdaze
Mar 24, 2013 11:34 AM
tapace
Jan 16, 2011 08:33 AM
JB73
Jul 31, 2010 04:47 PM
Datz All
Dec 9, 2007 06:13 PM
