Honda BF130 not starting - help pls
Hi Guys
I have a bf130, not starting at all. When turning the ignition key ON, the high pressure pump is working, but no voltage on the injectors. Checked all wiring, + from the main relay is coming but - from the ESM is not. Checked for codes but no codes are present. Went even through all the harness and checked all sensors. Was suspicious with the Map sensor so i changed it with a new one. Checked even all other sensors and seems that they are working fine. Checked resistance of injectors and they are around 14ohms (as per manual) Any idea please |
Sorry don't know anything about Honda's out board motor.
Looks like you already know what is wrong No power to the injectors? Any signal to turn on and off the injectors? |
Its the ECU that decides when to turn
Originally Posted by antoine
(Post 37387)
Crank sensor needs to know the shaft is turning. Anyway, did you find power to the fuel injectors? |
+12v from the main relay yes, but -12v from the ecu no. I connected a lamp to the 2 pin red plug to check the codes and it is remaining on.
That doesn't sound good.
I just don't know enough about this motor to say what to do next Sorry. |
Thanks, will try to get an ECU to test
