Honda BF130 not starting - help pls
Old Apr 18, 2021 | 10:02 AM
antoine's Avatar
Default Honda BF130 not starting - help pls
Hi Guys
I have a bf130, not starting at all. When turning the ignition key ON, the high pressure pump is working, but no voltage on the injectors. Checked all wiring, + from the main relay is coming but - from the ESM is not. Checked for codes but no codes are present.
Went even through all the harness and checked all sensors. Was suspicious with the Map sensor so i changed it with a new one. Checked even all other sensors and seems that they are working fine. Checked resistance of injectors and they are around 14ohms (as per manual)
Any idea please
Old Apr 18, 2021 | 02:54 PM
Sorry don't know anything about Honda's out board motor.
Looks like you already know what is wrong
No power to the injectors? Any signal to turn on and off the injectors?
Old Apr 19, 2021 | 01:17 AM
antoine's Avatar
Its the ECU that decides when to turn
Old Apr 19, 2021 | 08:10 AM
Understood, there should be certain conditions which the ECU sees before it will send the injector pulses
Crank sensor needs to know the shaft is turning.
Anyway, did you find power to the fuel injectors?
Old Apr 19, 2021 | 08:21 AM
antoine's Avatar
+12v from the main relay yes, but -12v from the ecu no. I connected a lamp to the 2 pin red plug to check the codes and it is remaining on.
Old Apr 19, 2021 | 08:25 AM
That doesn't sound good.
I just don't know enough about this motor to say what to do next
Sorry.
Old Apr 19, 2021 | 08:44 AM
antoine's Avatar
Thanks, will try to get an ECU to test
TNody14
Mar 28, 2021 03:29 PM
sensei
Feb 21, 2021 12:06 PM
proudfatherde
Jan 8, 2021 12:13 AM
niram2582
Jun 14, 2012 08:38 AM
truettb20a
Feb 27, 2011 05:33 PM
