90 Accord CEL CODE 12
Old Oct 6, 2010 | 10:38 PM
benitez63035's Avatar
Default 90 Accord CEL CODE 12
Hello just looking for some help.
I pulled the codes on my 90 Accord EX and got 1, 12, and 43
The next day I cleaned out Oxygen sensor, oil was in the plugs? and it took car of the Oxygen sensor(12) and fuel supply code (43). Now my problem is the EGR valve apparently. I just replaced it a month ago with an EGR valve form an 89' accord because mine had a hole in the diaphragm. BUT the plugs were different, so I just split the wires ans used my original plug. is that ok? is that why the code is coming up? any help is appreciated
Old Oct 7, 2010 | 09:51 AM
You would think one from an 89 would work ,but that one may be bad also,I would try a new valve it would be worth the money. then check your codes again ,I would be willing to bet that would solve the problem.
Old Oct 8, 2010 | 01:04 AM
jay929's Avatar
Hi! Welcome here.Its good that you joined this forum.I am sure you'll get lots of information from here.
Old Oct 8, 2010 | 09:27 PM
ok thanks thats what I'm thinking. tomorrow I'm gonna try to clean the EGR valve, but i don't think that will help it. And earlier today I pulled the codes and 43 came up again? I reset the ECU and it went away now just 12 again. I just thought tha was weird. Does anyone know the symptom of a bad EGR? i hear a knocking noise from the exhaust sometimes when I try to accelerate and it won't go away unless i lift my foot of the gas and accelerate again? Also right when i turn the car on its loud and shakes a little then goes to normal. My CEL only comes on once i start driving for a couple minutes.
Old Oct 9, 2010 | 01:24 PM
the knocking sounds like a timing issue,also if you have any upgrades cold air induction or chip you may want to run a little more octane,maybe mid grade
Old Oct 9, 2010 | 03:26 PM
I just ahve a cold air intake and catback exhaust? I'm planning on ordering the EGR monday
jackraider
Mar 18, 2015 03:20 PM
Bikeman982
Mar 18, 2011 12:32 AM
benitez63035
Oct 21, 2010 09:44 AM
Clay
Aug 9, 2009 11:55 AM
civicpryde
Feb 25, 2008 07:34 PM
