honda accord
Old Apr 24, 2012 | 01:12 PM
mchlfltchr's Avatar
Default honda accord
I have 87 Honda accord and I'm having problems with my clutch it is not engage I can't not put my car in gear while running I have to put the car in gear then start it and I can shift it by the rpms but have troble down shifting and does grind from time to time I did buy a clutch but not sure if that's the promblem I have adjusted the cable but cable looks streched and I checked the fluid but fluid is fine please help I don't want to put a new clutch in if I don't have too
Old Apr 26, 2012 | 10:32 AM
Welcome to the forum,you may have put the disc in backwards,or the Throw out bearing is bad.
Old May 10, 2012 | 03:41 AM
ian220's Avatar
Hi bro did get your problem solve?
Old May 23, 2012 | 05:46 AM
sellway's Avatar
welcome to Honda family
Old May 30, 2012 | 09:10 AM
your clutch pressure plate may have failed, not allowing the clutch to disengage to shift. check to see if the clutch throw out bearing arm is moving when you step on the clutch. (need a second set of eyes) if the throw out bearing arm is not moving, the clutch slave cylinder may have failed.
Old Jun 9, 2012 | 02:09 PM
RAYDOGZ's Avatar
Default clutch problem
the best thing to do in the future when installing install all 3 things new clutch throw out bearing and pressure plate so when u put everything back you dont have to take it back down to do 1 thing that will cost you more on the long run i would check throw out bearing might be bad
Old Jun 11, 2012 | 07:14 AM
Good advice.
