Need helP!
Old Aug 3, 2011 | 02:48 AM
jswaggs's Avatar
Default Need helP!
need help with 91 civic i took the whole distributor off and didnt put a mark on it so the timing was off when i put it back on.. ive been tryin to start the car no luck..tryin to figure out how to solve the problem
Old Aug 9, 2011 | 10:52 AM
Well I doubt you marked the shaft either,what you are facing is a little tricky,even veterans have problems sometimes,the site may help,good luck.http://www.secondchancegarage.com/public/175.cfm
Old Aug 27, 2011 | 04:37 AM
91haydenSI's Avatar
ive never marked mine and have never had problems getting it to work.. did you turn the crank after you removed the dizzy?? because if not there are 2 different sized notches on the shaft it should slide right on and not be out of timing
okhozi
Jan 6, 2010 09:10 AM
90civicDX
Apr 1, 2009 09:32 AM
91hondaaccord
Jul 21, 2008 05:15 PM
