need help my check engine has been on for like a year now
Old 05-28-2009 | 03:48 AM
chato_9's Avatar
Exclamation need help my check engine has been on for like a year now
hey
i have a 95 honda civic ex 1.6 vtec
i bought the car about one year ago after driving it for about 3-4 months
tone day i started my car and was driving it when i noticed my check engine was on ??? im new to this honda thing i also notice my rpm doesnt go above 1 or close to one when i start the car!!! is this bad
can some1 help me
Old 05-28-2009 | 04:22 PM
welcome to the forum. Take it to a shop that will do a free download and find what the code is, this will tell you what might be going bad. make sure that your gas cap is on tight.
rpm not going up to 1k could be a leaking vaccum line or idle valve control
Old 05-28-2009 | 07:30 PM
chato_9's Avatar
Exclamation
i checked my cap but i have no idea what the vacuum line or idle valve control are !!!
can u break it down or do u just suggest for me to take it to a shop!
but if i take it to a shop and its a free diagnosis do you think they will give me a print out of the codes they get?
Old 05-29-2009 | 06:41 PM
It would be a great idea for you to purchase a service manual so we all can understand what is being talked about. Vaccum lines sometimes produce a small hole, this will allow unwanted air into the manifold system causing the engine to run poorly, or slow. the idle control valve allows the proper amount of air into the induction system to run the engine. Go to autozone.com, register for free, and put your car info in. Go to repair and find how to fix items on the car, go to component location and you will find parts on your engine, vaccum line, idle control valvel, etc. also go to hondaautomotiveparts.com and you will see the parts diagram of your car.
Old 06-02-2009 | 05:07 AM
chato_9's Avatar
Hey I went to a shop and they couldn't find the cable to connect the scanner is that bad!!??
Old 06-05-2009 | 07:39 PM
no it is not bad, need to get a manual, where it will show you where the connecter is. Did you go to autozone.com to locate the part, also to hondaautomotiveparts.com to find the parts. You can also go to the library, they may have the helms, haynes, chilton, or some type of honda book to assist you.
Old 06-06-2009 | 04:27 AM
chato_9's Avatar
Exclamation acmech52 thanks!!
acmech52 thanks for the help i got my car checked out and it was the idle control valve thats why my checkengine is on!!
i also found out that pepboys checks ans gives you print out of the codes for fee!!!lol.....
thanks man your were a lot of help!!!
Old 06-09-2009 | 08:48 PM
honda258's Avatar
hi all, im Long, very happy know people
James Blevins
01-15-2015 12:06 AM
bigtex
10-19-2012 03:56 PM
AcuraPartisan
11-23-2010 04:52 PM
AcuraPartisan
11-23-2010 04:51 PM
Raabhimself357
11-10-2010 12:56 AM
