03 Odyssey Power Steering HELP! Foam
Old Jun 23, 2010 | 04:03 PM
apopkarvp's Avatar
Default 03 Odyssey Power Steering HELP! Foam
While I was changing the timing belt, water pump, etc. I broke the wires from the power steering pressure switch located on the high pressure side close to the frame. When I first started the car, I notices a whirring sound from the power steering pump, the van was revving between 1000 and 1500 rpm and I turned it off. I have repaired the switch (tried to replace it but can't get it loose. I also identified a leak near the power steering reservoir and replaced it and the 2 hoses that are connected to it. I have bled the system, but I still get foam. The power steering pump sounds better, but I am wondering what the fix is. Can the power steering pressure switch malfunctioning cause the foaming? Could the pump (seal?) be causing this? Or is there another potential problem. I have looked at all of the lines, Everything looks dry, even along the rack. Any suggestions would be appreciated. Thanks
Earthcritter71
Apr 25, 2011 11:13 AM
apopkarvp
Aug 5, 2010 09:55 PM
golfer1512
Aug 26, 2009 07:14 PM
mike0094
Oct 18, 2008 11:10 AM
HondaCivicCX
Jan 6, 2007 05:31 PM
