2001 Odyssey A/C Charging Questions
Old Jul 5, 2014 | 03:35 PM
joncav's Avatar
Default 2001 Odyssey A/C Charging Questions
The A/C Compressor would make strange grinding noise when turning on, so I took to the shop. They replaced the compressor, drier, vacuumed the system. After picking up the A/C was only cooling (while sitting) at about 60 degrees F, 48 degrees F while driving.
I'm expecting 34-40 degrees driving maybe 40-45 while sitting from the vent. Is this an incorrect assumption?
My mechanic said the pressure of the system with clutch engaged is below, does this sound right?
LOW 45 PSI
HIGH 225 PSI
Any help would be appreciated.
soberdaze
Mar 24, 2013 11:34 AM
kayslay
Mar 29, 2009 12:26 AM
Datz All
Dec 9, 2007 06:13 PM
Rob
Jan 9, 2007 02:17 PM
Nikkilara
Aug 22, 2006 03:53 AM
