2012 3.5l I Vtec - throttle body
Old Jul 3, 2023 | 12:54 PM
salishin's Avatar
Question 2012 3.5l I Vtec - throttle body
P0506 DTC, clean throttle body butterfly, reassemble and now the engine hunts RPM bad. Removed thottle body again everything looks clean. Did I introduce a vacuum leak somehow, to cause my RPM hunting? On the downstream side of the throttle body there is a port that looks as though coolant has been leaking (white powder like residue remaining). Does this assembly contain the idle air control valve? If the butterfly valve does not completely close should I adjust the set screw mechanical stop to allow it to close more? Is there a procedure for calibrating (setting up) this equipment after maintenance procedures?
Old Jul 3, 2023 | 03:56 PM
Is the butterfly geared? If so, you may need to replace the throttle body. Do you have a scan tool {not code reader)?
Old Jul 4, 2023 | 11:42 AM
salishin's Avatar
Yes the butterfly is geared. Disassembled the whole thing and the motor works good in both directions, Yes I have an Autel (AutoLink)AL519
Old Jul 4, 2023 | 06:48 PM
Did you exercise the butterfly by hand? Did you use the scan tool to relearn the idle?
Old Jul 6, 2023 | 01:02 PM
salishin's Avatar
I did exercise the butterfly by hand. It turned out I created the difficulty by not ensuring the connector for the MAP sensor was secure. Due to having to travel for work I ended up bringing it to a shop. And they fised it up. I do remember seeing that MAP sensor DTC, post throttle body cleaning. But did not take the time to check connection integrity. If it would have said open circuit, I probably would have. Thank you kindly "grcauto" for your time and efforts.
Old Jul 6, 2023 | 09:40 PM
Glad you got it fixed.
Old Sep 24, 2023 | 02:23 PM
When was the last time your transmission fluid was changed ? Dirty fluid can cause the transmission to shutter
Deube
Apr 2, 2023 04:10 PM
Gino Savoie
Sep 16, 2020 08:28 PM
Jason899
May 7, 2019 07:38 PM
ronzdad
Nov 18, 2010 12:57 PM
HondaMaren
Apr 15, 2007 09:43 AM
