2016 VCM issue
My son was driving down I71 in Ohio when the engine began chugging and became undriveable. Turns out it was the VCM issue, plugs 1 and 6 fouled. Appears the VCM system turns off several pistons when cruising which can cause the rings to leak over time and be damaged. Prior models of the Odyssey were part of a settlement over the issue, but not the 2016 generation. Anyone else have this issue? So far Honda is washing its hands of this.
Independent mechanic changed out the #6 plug, fouled by oil. Can happen again any time. put in Techron additive to free up the rings, might work. There is a kit you can buy to disable the VCM system so the two cylinders never stop firing. If the rings for #6 do not free up, then will need a ring job, over $3k. #1 cylinder could do this also. Honda wrote back saying they do not have a service bulletin, nothing they will do.
2019odysseyelite
May 29, 2019 09:23 PM
