2018 Honda Odyssey Misfiring
Old 06-22-2021, 05:53 PM
AVerayB's Avatar
Default 2018 Honda Odyssey Misfiring
My 2018 Honda Odyssey just started misfiring. There is no code. My mechanic determined it is Cylinders 3 and 6. But he can't figure out what is causing it. Any suggestions? Anyone with the same issues? I have had so many issues with this model.
Old 06-22-2021, 10:40 PM
Did the mechanic check the misfire counter on his OBDII scanner?
Causes for misfire can be coil over plugs are faulty
Or, bad fuel, faulty fuel injectors, bad valves, bad head gasket, poor grounds, large gap spark plugs.
Figuring out the misfire requires a bunch of testing
And on a 6 cylinder engine, it is tough to access all the spark plugs or injectors\
Lot of work for diagnostics and very little money.
So some mechanics will just throw up their arms and pass.
madhuraam
01-22-2019 08:39 PM
jlo77mb5AB
05-11-2018 08:39 AM
Fishwest99
07-08-2017 06:32 AM
trev0006
11-07-2013 12:59 PM
Quick Reply: 2018 Honda Odyssey Misfiring
