check engine
Old Mar 17, 2008 | 05:45 PM
billybop45's Avatar
Default check engine
Hi I have a 01 Odessey that I love vey much. I just had someone at auto parts store check codes from check engine light.
I got the following codes
p 1491
p 0301
p 0304
p 0305
p 0300
p 1399
What amI looking at here?
Before I go to a dealership and overpay is there one thing I should be looking at for a fix?
How could all my cylinders be misfiring like this? Is there a central control that could be the issue here?
Old Mar 17, 2008 | 05:52 PM
billybop45's Avatar
Default RE: check engine
P S It is a 6 cylinder
Old Mar 18, 2008 | 08:13 AM
Welcome to the forum billybop45 enjoy your stay, hope some of us may be able to assist you.
p1491 egr vlv lift insufficient detected
p 0301 misfire, #1 cyl or random misfire
p 0304 misfire, #4 cyl or random misfire
p 0305 misfire, #5 cyl or random misfire
p 0300 ramdom misfire
p 1399 stop for code set up
Old Mar 18, 2008 | 10:28 AM
billybop45's Avatar
Thank you for taking the time....sounds like I am up *&$%creek without a paddle! I only hope it is a central unit causing the misfires and not individual units!
Old Mar 19, 2008 | 02:47 AM
not yet, how many miles do you have on the odyssey, it may be a minor tune up. It could be an individual coil, it could be the plug wire. The hondas don't go bad all at once, and they last a long time. Do you have a service manual or helms or chilton to help you out on trouble shooting and repairing your van?
Old Mar 19, 2008 | 03:01 AM
egr valve might be dirty with carbon, or vaccum line is not opening the valve all the way, check line, or remove egr and clean off carbon, and or ck the diaphram for proper travel. Or may want to send to the the shop to fix. May call around and find out if there are any good shops that work on your type van.
samuel_gatech
Nov 4, 2009 04:46 AM
papic03
Mar 6, 2007 09:17 PM
silverbullet
Feb 19, 2007 08:26 PM
cpatd
Nov 13, 2006 02:03 PM
whermanov
Sep 23, 2006 04:16 PM
