Hissing noise on 2002 odyssey
Old 03-31-2008, 01:04 AM
KRLT's Avatar
Default Hissing noise on 2002 odyssey
Hi there guys,
New to the forum.
I have a 2002 Honda Odyssey EX, v6.
My question is,
When in drive mode and the RPM reaches like 2,000. I would hear this high pitch noise, as I accelerate, it gets louder. The pitch kind of goes away at 60mph, or I just don't hear it.
I checked the ac, heat, but its not that. I also replace my serpentine belt since it is time anyway, but noise still there.
If you are in park and rev the engine, the hissing noise is not there, only when you are in D mode.
And no it is not wind noise. On days that there is no wind, you can hear it way better.
Anyone have any suggestion?
Thanks,
KRLT
Old 03-31-2008, 06:10 PM
Default RE: Hissing noise on 2002 odyssey
Welcome to the forum KRLT Do you or a friend have access to a vehicle hoist that keeps the wheels free to turn, or sturdy jack stands with good chocks to jack up the drive wheel off the ground. Then you can run your engine up to rpm in gearand listen for the hissing sound. make sure your wheels are free from the ground and the chocks are infront or back of the wheels on the ground.Be very careful to not let the spinning wheel catch anything.
Old 04-01-2008, 01:45 AM
KRLT's Avatar
Thanks, I will give that a try and see if I can pin point where it is coming from.
Old 06-05-2018, 09:46 PM
boie5319's Avatar
Default Hissing Nois
I have the same problem n replaced both front hub and bearing set and hissing hi-pitch noise still there. I checked for intake leak as forum have suggested but couldn’t find no leak. I’m still hunting!
Bailey42
12-18-2017 07:05 PM
poscivic05
02-27-2012 10:00 AM
mike0094
08-05-2010 02:58 AM
atl
09-06-2008 05:07 PM
sebu
05-10-2007 05:00 AM
Quick Reply: Hissing noise on 2002 odyssey
