-   Odyssey Forum (https://hondaforum.com/forum/odyssey-forum-15/)
-   -   Hissing noise on 2002 odyssey (https://hondaforum.com/forum/odyssey-forum-15/hissing-noise-2002-odyssey-2384/)
KRLT Mar 31, 2008 01:04 AM
Hi there guys,
New to the forum.
I have a 2002 Honda Odyssey EX, v6.
My question is,
When in drive mode and the RPM reaches like 2,000. I would hear this high pitch noise, as I accelerate, it gets louder. The pitch kind of goes away at 60mph, or I just don't hear it.
I checked the ac, heat, but its not that. I also replace my serpentine belt since it is time anyway, but noise still there.
If you are in park and rev the engine, the hissing noise is not there, only when you are in D mode.
And no it is not wind noise. On days that there is no wind, you can hear it way better.
Anyone have any suggestion?
Thanks,
KRLT
acmech52 Mar 31, 2008 06:10 PM
RE: Hissing noise on 2002 odyssey
Welcome to the forum KRLT Do you or a friend have access to a vehicle hoist that keeps the wheels free to turn, or sturdy jack stands with good chocks to jack up the drive wheel off the ground. Then you can run your engine up to rpm in gearand listen for the hissing sound. make sure your wheels are free from the ground and the chocks are infront or back of the wheels on the ground.Be very careful to not let the spinning wheel catch anything.
KRLT Apr 1, 2008 01:45 AM
Thanks, I will give that a try and see if I can pin point where it is coming from.
boie5319 Jun 5, 2018 09:46 PM
Hissing Nois
I have the same problem n replaced both front hub and bearing set and hissing hi-pitch noise still there. I checked for intake leak as forum have suggested but couldn’t find no leak. I’m still hunting!
