Powe Door Problem 2002 Odyssey
Old Mar 15, 2016 | 09:41 PM
brayampettai's Avatar
Default Powe Door Problem 2002 Odyssey
Hi
The Driver side Power door does not close nor open in my 2002 Honda Odyssey. When I press the switch it gives a geek geek sound and the door does not close/open.
I have tried to re-set the circuit and it did not fix the issue.
any ideas on how to fix.
thanks,
Balaji.
Old Mar 16, 2016 | 06:24 AM
welcome to the forum. have you checked to see if the motor is operating properly.
Old Mar 22, 2016 | 10:09 PM
IndianaJohn's Avatar
sometimes you have to turn the switch to off and then then manually open and close the door to reset it. You should also check to see that the roller bearings are not worn. If you have much noise at all when the door opens, then those are most likely bad. Mine got so bad, the center arm started cutting into the paint. It isn't hard to replace and there are a couple of great youtube videos that show you how to do it.Name:  11846725_871525596257910_8775339934099402495_n.jpg
Old Mar 22, 2016 | 11:29 PM
Thanks. how to find if the motor is working.
When you say turn off the switch, is it the door/window switch.
Thanks, I am a beginner to all this.
Balaji.
Old Mar 22, 2016 | 11:36 PM
Balaji.
On my 2003, there is a switch above the two open/close door switches that turn off the sliding doors. I often use that to prevent the kids from opening the doors. Anyway, turn that off and then manually slide the door completely open, check the tracks to make sure no foreign objects are there, and then completely close the door. Then turn the switch back on and see if the door works.
Old Mar 23, 2016 | 03:15 PM
Hi IndianaJohn,
I did the steps and it did not work.
I opened the side bar and the wire attached to the motor and door is intact.
I don't want to pull the inside panel completely out If I don't have to, to fix this issue. How can I find if the motor is working?
thanks,
balaji.
Old Mar 23, 2016 | 07:35 PM
Hi IndianaJohn,
thanks,
balaji.
Sorry, but I'm out of ideas. If you're getting power to the motor (as evidenced by the noise when the button is pushed). Fortunately, I've always been able to get the doors running again by manually opening and closing them. If you push the door to completely open and then try to get the door to close on it's own, do you get the same sound? sorry I could be of more help.
Clint14
May 4, 2015 07:06 PM
desastre
Mar 17, 2013 07:25 PM
ahsank2
Apr 29, 2012 04:07 PM
bruceb
Nov 24, 2010 01:35 PM
pvl717
Apr 2, 2007 05:00 AM
