rpm < 2000 with pedal to floor and no CEL/codes!
Old Apr 18, 2018 | 10:29 AM
KKody311's Avatar
Default rpm < 2000 with pedal to floor and no CEL/codes!
Noticed yesterday the 2008 Odyssey on hills bogged way down to 1000-1500 rpm or so and acted like it was out of fuel and engine nearly shutting off. Check engine light does not come on either. Let off the pedal, its fine (idle and all)..... slowly press pedal to the floor and rpm will go up normally. Checked the DBW fuse and DBW relay and all was good. Any idea what this could be? I find it odd the OBC does not recognize anything wrong and throw code(s). Thought it could be a clogged cat perhaps??
Old Apr 22, 2018 | 09:32 AM
It maybe the converter as you mentioned,or possibly the fuel pump is going bad,have a back pressure check done for the converter and for the fuel pump if you are good with the wrench pull a fuel line and try cranking it to see if you have good pressure with a can ready to catch the fuel or buy a pressure gauge,or turn the ignition on bit don't crank it listen for the fuel pump to come on in the gas tank,does it sound strong? Good luck.
ZionXIX
Aug 2, 2016 01:27 PM
hcashew
Aug 1, 2014 11:14 PM
iamatt
Aug 13, 2013 10:38 AM
skipyo
Jul 27, 2009 07:33 PM
dgresham2134
Apr 18, 2008 12:12 AM
