Troubleshooting '05 Odyssey driver sliding door
I have an '05 Odyssey which is having trouble with the driver sliding door. It stopped working (wouldn't even open manually) and I have done the following in an effort to fix it:
Is there anything else I can try to get this going again?
- I replaced the bracket that is used by the sliding door motor to pull the door back and forth. I also replaced the rail it goes in at the same time. (The previous bracket had broken rollers).
- I replaced the sliding door motor & cables.
- I replaced the controller that's in the back (normally behind the spare tire).
Jschoend
Apr 25, 2019 01:50 PM
