Off Topic A place to boldly go off topic... just about anything goes.
b18 motor
Old Aug 18, 2007 | 08:54 PM
PRELUDEMAN09's Avatar
Default b18 motor
I just bought a 1993 honda prelude and i want to put a b18 motor in it. It is an Si so sould i gowith the b18 or the vtec motor give me advice.
Old Sep 18, 2007 | 07:07 AM
elflako973's Avatar
Default RE: b18 motor
A b18 in a prelude? I've never heard of dat, if u have an h22 why would you downgrade 2 a b18? H22 is better don't do dat. B18 is good for small body hondas like crx, hatchz, integras, but not preludes.
Old Dec 5, 2007 | 04:23 PM
neonstryde's Avatar
buuuuuut if i had to say i would obviously go vtec. personally i would geta b18c motor. vtec always better if u got the option
Old Dec 9, 2007 | 04:59 PM
Deleted User's Avatar
Banned
Default [Deleted]
[Deleted by Admins]
Old Jan 29, 2009 | 09:45 PM
desperado's Avatar
You could do either and see a decent improvement. I had a friend drop a B18c into his Prelude and it gave him a lot more power.But, the difference is:
H22: 220 hp@ 7200rpm, 163 torque @ 6500rpm,
B18c: 170 hp @ 7600rpm, 128 torque @ 6200rpm,
B18c specR 195 @ 8000rpm, 130 torque@ 7500 rpm
I have a 95 Integra that I'm going to drop a B18c specRinto when the stock motor dies. Personally, I would prefer the efficiency of a VTEC. If you increase the power too much without beefing up the transmission, you might end up having to replace it next.
Old Jan 30, 2009 | 01:01 AM
asianinvasion84's Avatar
you probably have an h23 in a 93 dont you? I would just save up to swap an h22a. You could also build the motor and turbo it, which is what im doing. The h23 block is strong, but you need to make sure you build it first with the right stuff, if you do, you could boost it to 8-10 psi. You will get more power and it would cost about the same. to swap a motor will cost you like 2000+ for a good h22a and if you dont know a mechanic, like a thousand to put in. good luck
Cam Shafted
Jun 8, 2007 04:58 PM
seekingbass
Jan 22, 2007 11:05 PM
rainviller
Dec 15, 2006 03:45 PM
asoberbassist
Nov 16, 2006 08:05 PM
bobby
Mar 22, 2006 03:28 PM
