Off Topic A place to boldly go off topic... just about anything goes.
Used car buying tips
Old Jun 14, 2010 | 03:02 AM
sujee12's Avatar
Default Used car buying tips
1. Check how neat the car is in its external appearance. You must have a look at the car under bright sun so that* any uneven paint jobs can be easily identified. Incase you identify one, run your hand through the body line and you would defineatly find there is a difference in smoothnees. If the damage is huge, avoid such car.
** 2. Check the underbody of the car for any major scratches/damages. people generally make up the exteriors but there is not much they can do to coverup things under the car.
** 3. Check for the original stickers of the car in the engine area. You can see the natural wear and tear if the area is not quiet touched which is a good sign.
** 4. Ask if the service schedule has been maintained.
** 5. Make sure the tires, are in good condition. This could incurr sizeable cost incase they require replacement.
** 6. Like already mentioned, the lesser the car clocked on the ODO, better it is.
** 7. Check for the rubber beadings on the door.* Incase the car had a major collision, the impact can be easily see.
** 8. While take a test ride do not switch the music system On. Also roll the windows up for first few kilometers witout the AC or the Blower On. This will give you a clear sounds from the car's body and the engine. You mechanic can help you with the
Old Jun 14, 2010 | 10:33 PM
nickwayne's Avatar
Its so nice of you to share the tips of buying a used car.Its very useful for some one new here.Thanks.
MikeSmyth
Dec 20, 2013 01:17 PM
maheshika
Mar 14, 2013 11:26 AM
reese77
Nov 7, 2011 09:33 AM
unospam777
Sep 9, 2009 04:00 AM
jonsaysthat
May 28, 2008 06:54 AM
