Climate control system - need to manually turn on AC
Old Jun 21, 2021 | 07:32 PM
Chimerakip78641's Avatar
Default Climate control system - need to manually turn on AC
We have a 2020 Pilot and the manual says the car adjusts the mixture of cool and warm air to keep the temperature where you set it. I thought it would turn the air conditioner on and off as it needed it. But we have to do that manually - in this late of a model year? One example - if we have it at 68 degrees and the AC is on, to warm the air up to 75 we have to turn off the AC. If this is how it works thats very disappointing for what you spend and all the other fancy features. Or is it broken? Thanks
Old Jun 21, 2021 | 09:05 PM
welcome to the forum. have you checked with the Honda Dealership. your vehicle is under warranty and everything should work as per owners manual. if there is a problem, Honda can explain or fix it or show you what happened.
rickpaulos
May 16, 2021 05:35 AM
mrbilly1948
Oct 14, 2019 02:48 PM
ssal
Sep 23, 2016 10:20 AM
stuckpipe
Aug 5, 2014 11:20 AM
t-dogg
Aug 16, 2009 10:47 AM
