Door won't lock
Old Apr 1, 2013 | 12:20 PM
DavidM's Avatar
Default Door won't lock
I have a 2004 Honda Pilot. A couple of months ago I had a minor accident which damaged the rear door on the driver's side. I had it fixed, but since picking it up from the body shop, the other rear door (on the passenger side) won't lock automatically with the remote or the master door lock switch. I can only lock it manually pushing down the tab on the door itself. All the other doors, including the one that was worked on, lock fine.
My question: is that just a coincidence that this started once I picked the car up from the body shop, or, even though they supposedly worked on the other rear door only, they still could've somehow affected the passenger side rear door?
Old Apr 2, 2013 | 09:13 AM
Welcome in,it's possible the impact to the rear door could have cause the connection to come loose on the problem door,take the door panel off and check for power to the switch and if connections are tight.
nazz
Feb 28, 2009 12:57 PM
wannabedivin
Jan 20, 2009 02:57 AM
inewton55
Nov 25, 2008 10:00 PM
Imaprincess
Sep 13, 2006 02:48 PM
cdagza
May 3, 2006 09:48 PM
