drain bolts - 2016 Pilot
Old Apr 28, 2019 | 01:27 PM
Ken2016's Avatar
Default drain bolts - 2016 Pilot
I am dropping all lubricants next week on my 2016 Pilot (oil, transfer case, trans, and rear-end). I would like to replace the drain bolts with magnetic tipped ones.
Are the drain bolts the same for all 4 locations? Recommendations on were to buy the magnetic replacements?
thanks
Ken
Old Apr 30, 2019 | 12:52 PM
dgough's Avatar
Don’t know about magnet bolts but I recommend replacing the oil bolt with a Fumoto valve.
I believe that the trans bolt is already magnetized.
Old Apr 30, 2019 | 07:48 PM
Welcome in,I would not use a drain valve myself,it's possible to run over something and open that valve ,if this happens you have seconds to shut your engine down. Magnetic plugs are fine,your parts house of choice will no the demensions of them.
Old May 1, 2019 | 09:25 AM
dgough's Avatar
The valve is tucked up by the pan. It’s very unlikely to be randomly hit by something. It might be more likely that you’d hole the pan itself with the same result or strip the bolt hole.
Old May 1, 2019 | 12:12 PM
What I'm referring to is one that has a flip down action that opens a gate valve.
Old May 1, 2019 | 12:48 PM
dgough's Avatar
I think the Fumoto uses a ball valve. It doesn’t protrude past the bottom of the pan. It also designed so a casual knock won’t open the valve.
89hondacrx
Feb 21, 2021 02:48 PM
Decolliber
Dec 27, 2019 01:25 PM
hondaguy1
Feb 1, 2017 06:11 AM
Marc
Aug 12, 2016 07:45 PM
Hondagal1
Sep 20, 2013 11:50 AM
