Honda Pilot Passenger Window
I replaced both of my window switches in my 2016 honda pilot EX. The master driver's door/power window switch and the front passenger door/window switch. I was having issues with the passenger window not going up and down, so I replaced both switches. Now, I have a new issue. When I bring the driver window down, the front passenger goes down as well. It doesn't go down all the way and stops about two inches from the closed position. I tried to find the relay for the window but have no idea where to find it. Does anyone know what this issue is related to and how I can resolve it, if possible?
My rear windows work fine, and the driver window also works but also lowers the front passenger window. Also tried disconnecting the battery to see if the problem corrected itself. Still having the same issue. *UPDATE - reprogrammed the driver auto up and down and the switch no longer moves the passenger window down. However, I can't control the window from the driver's side, and on the passenger side, the window only goes down 2 inches at a time with each press. Thanks in advance |
Check the wiring in the loom between the door and A pillar.
You might have to program auto up and down on the passenger's side also
Originally Posted by avisitor
(Post 42465)
Originally Posted by kings415
(Post 42468)
my passenger window does not go down smoothly. i have to press the passenger switch 6-7 times before the windows goes down completely. I also can't control my passenger window from the driver side. every other window works. I'm stiluck and don't know what to do. I tried the window programming on both sides and nothing.
It could be the window is stuck??
