Honda Pilot Passenger Window
Old Jul 22, 2023 | 01:22 PM
kings415's Avatar
Default Honda Pilot Passenger Window
I replaced both of my window switches in my 2016 honda pilot EX. The master driver's door/power window switch and the front passenger door/window switch. I was having issues with the passenger window not going up and down, so I replaced both switches. Now, I have a new issue. When I bring the driver window down, the front passenger goes down as well. It doesn't go down all the way and stops about two inches from the closed position. I tried to find the relay for the window but have no idea where to find it. Does anyone know what this issue is related to and how I can resolve it, if possible?
My rear windows work fine, and the driver window also works but also lowers the front passenger window. Also tried disconnecting the battery to see if the problem corrected itself. Still having the same issue.
*UPDATE - reprogrammed the driver auto up and down and the switch no longer moves the passenger window down. However, I can't control the window from the driver's side, and on the passenger side, the window only goes down 2 inches at a time with each press.
Thanks in advance
Old Jul 22, 2023 | 06:47 PM
Check the wiring in the loom between the door and A pillar.
Old Jul 23, 2023 | 12:58 PM
You might have to program auto up and down on the passenger's side also
Old Jul 23, 2023 | 01:28 PM
kings415's Avatar
my passenger window does not go down smoothly. i have to press the passenger switch 6-7 times before the windows goes down completely. I also can't control my passenger window from the driver side. every other window works. I'm stiluck and don't know what to do. I tried the window programming on both sides and nothing.
Old Jul 23, 2023 | 09:49 PM
Read post 2
Old Jul 23, 2023 | 10:11 PM
It could be the window is stuck??
DavidTirado
Mar 30, 2020 07:31 AM
juco
Nov 24, 2008 05:43 PM
Gearshift
Aug 21, 2007 09:43 AM
99CivicEX
Aug 1, 2007 11:36 AM
