Prelude Forum This sporty coupe was popular with anyone who wanted a sporty, economical ride.
300volts to starter!
Old Jun 11, 2023 | 01:05 AM
nothatbright's Avatar
Default 300volts to starter!
So i recently swapped an h22a4 into my 94 prelude and moved the fuse box into the passenger side by the ecu and now my multimeter is reading 300 milivolts to the starter! Any ideas on why?
Old Jun 11, 2023 | 02:35 PM
Meter problems? Where on the vehicle do you get that kind of voltage?
Old Jun 11, 2023 | 03:08 PM
sorry i meant to say milivolts
Old Jun 11, 2023 | 04:08 PM
That means zero really. What do you get with KOEO. Lights? Turn to start and anything? Clicks?
We need something to go on.
I have the factory info for it if you need something.
Old Jun 11, 2023 | 04:31 PM
So all the dash lights work as well as the headlights no clicks from the starter, I just pulled the main relay and it smells burnt so I’m gonna replace that right now and see what happens
Old Jun 11, 2023 | 04:49 PM
alright we’ll I just replaced the main relay and still nothing
Old Jun 11, 2023 | 10:43 PM
What is the ignition switch doing?
Old Jun 12, 2023 | 01:50 PM
nvm I finally figured it out it was a ground
Old Jun 12, 2023 | 08:27 PM
Could you elaborate?
Old Jun 12, 2023 | 08:57 PM
  #10
When i moved the battery to the trunk i didnt notice the ground attached to the transmission so i just ran a ground from the transmission to the battery in the trunk and turned over no problem
