Prelude Forum This sporty coupe was popular with anyone who wanted a sporty, economical ride.
VALVE COVER PRESSURE!!!!!
Old Nov 6, 2008 | 01:34 AM
H22ACCORD's Avatar
Default VALVE COVER PRESSURE!!!!!
I HAVE A SMALL FILTER ON ONE OUTLET OF THE VALVE COVER. AND A RUBBER HOSE RUNNING FROM THE PCV VALVE TO THE INTAKE MANIFOLD. WHEN I RACE AND THE OIL PRESSURE BUILDS ALOT OF OIL SHOOTS OUT OF THE BREATHER I PUT ON THE VALVE COVER, WHAT CAN I DO????? OIL CATCH CAN?
Old Nov 6, 2008 | 06:34 AM
Default RE: VALVE COVER PRESSURE!!!!!
If your pvc valve is in good working , and at top end oil is blowing out, it may be from excessive blow by. how many miles do you have on the engine? ( since overhaul) have you done a compression check lately?The catch can will also work if you can get it to drain back into the engine crank case. Aircraftengines have this feature.
m.e.greene
Aug 24, 2019 01:36 PM
Joey86
Apr 12, 2013 08:10 PM
bettystech
Jan 22, 2008 04:39 AM
Dominus
Oct 30, 2007 08:40 PM
SCCinc
Oct 8, 2007 03:53 PM
