Drivers door lock
Old Apr 16, 2020 | 08:40 AM
godzichl@yahoo.com's Avatar
Default Drivers door lock
I have a 2013 Ridgeline RTL. My drivers door lock doesn’t unlock unless I insert the key into the lock and force the lock open and hold the key in the unlocked position. I cannot open the door from the inside using the button, it will not move from the locked position. The lock in is a locked position at all times. The unlock button on the key unlocks all the other doors but not the drivers door
Any solutions.
Old Apr 16, 2020 | 09:46 PM
Sounds like the lock actuator is stuck in closed position
Would take off door panel and investigate
If it is the actuator then must be replaced or repaired
Good luck
Old Apr 17, 2020 | 08:00 AM
Was my best guess to. Thanks
theleeb
Jul 18, 2022 09:07 AM
Berg1947
Jan 6, 2022 02:44 PM
Quazi11
Sep 20, 2019 10:06 PM
Podenco
Dec 7, 2016 03:56 PM
Julie Landry
Mar 13, 2012 11:26 AM
