Wheels and Tires All wheel and tire discussion
constructions
Old 05-12-2010, 10:43 AM
durga987's Avatar
Default constructions
A bicycle wheel is a wheel, most commonly a wire wheel, designed for a bicycle. A pair is often called a wheelset, especially in the context of ready built "off the shelf" performance-oriented wheels.
Bicycle wheels are typically designed to fit into the frame and fork via dropouts.
The first bicycle wheels followed the traditions of carriage building: a wooden hub, a fixed steel axle (the bearings were located in the fork ends), wooden spokes and a shrink fitted iron tire. A typical modern wheel has a metal hub, wire tension spokes and a metal or carbon fiber rim which holds a pneumatic rubber tire.
nfl sports betting
hotel deals
