02 crv hard start
Old Apr 29, 2024 | 09:44 PM
Mcfam's Avatar
Default 02 crv hard start
02 crv seems like it is starving for fuel on cold start only. Cranks but it won’t start sometimes. When I do finally get it started it surges from 1000 to 1500 for a couple minutes.
it has spark on all 4 cylinders
it has fuel at all 4 injectors
starting fluid doesn’t help
no cel light or codes
any ideas or help would be appreciated!!
Old Apr 29, 2024 | 09:47 PM
Your testi9ng is what?
If you have both spark and fuel it would run. I think your spark may be a problem.
Old Apr 29, 2024 | 10:20 PM
Mcfam's Avatar
It will run it is just the starting the 1st time is a real problem
Old Apr 30, 2024 | 06:46 AM
Just Ducky's Avatar
Default Combustible
Just a thought:
Have you tried something like Kolor Kut or Gasoila paste in your fuel tank? Both of these products will detect water in your fuel.
Another way you may eliminate a possibility is to change your fuel source but if you have settled water in your tank that may not work effectively for quite some time.
I mention this because you state that you have fuel and spark and it runs normally shortly after starting.
Old Apr 30, 2024 | 11:30 AM
Mcfam's Avatar
Got car running yesterday!! Let it sit for an hour and tried again. It started but took a couple extra cranks! Let it sit overnight and it just cranks again no start. Started over checking everything:
Has spark
noticed fuel wasn’t at fuel rail at 1st. Cranked it a few minutes then got fuel and could start car.
i think fuel pump is getting ready to go out and is to weak to prime system. Does this sound right to anybody else or do I have a separate problem?
Old Apr 30, 2024 | 03:18 PM
Bubbalou88's Avatar
Has spark
I had a 2021 car do that and it was the fuel pump in my case.
Old Apr 30, 2024 | 07:35 PM
Sounds like it's losing the prime.
Old Apr 30, 2024 | 07:40 PM
Mcfam's Avatar
That is what I think but what could cause that and why doesn’t the fuel pump compensate?
Old May 1, 2024 | 12:18 PM
The check valve in the pump is bad. You need a new pump.
Old May 3, 2024 | 01:27 PM
  #10
Mcfam's Avatar
Fuel pump didn’t fix could it have slipped a tooth on timing? Would that keep it from starting or just make it run bad?
