02 crv hard start
Old May 3, 2024 | 10:31 PM
  #11
Check the timing.
Old May 4, 2024 | 08:59 AM
  #12
Just Ducky's Avatar
Default Switch
You went from having fuel in post 1 to not having fuel in post 5.
Good recommendation from grcauto based on post 5. New pump did not correct the problem so now you are talking about a timing issue.
If that is the case, a simple timing check (as suggested) will tell you if you are on the correct path.
Old May 4, 2024 | 09:20 PM
  #13
Originally Posted by Mcfam
02 crv seems like it is starving for fuel on cold start only. Cranks but it won’t start sometimes. When I do finally get it started it surges from 1000 to 1500 for a couple minutes.
it has spark on all 4 cylinders
it has fuel at all 4 injectors
starting fluid doesn’t help
no cel light or codes
any ideas or help would be appreciated!!
If it is a cold start problem then it could be the Engine Coolant Temperature sensor. The CRV has two. One is on the radiator and is basically a temperature switch, It closed when the coolant is hot and completes the circuit for the radiator fan. The second ECT sensor is on the engine. It tells the ECU when the engine is cold or warm. Cold is open loop and the ECU will use a fuel map stored in the ECU. When warm, the ECU will use the information coming from the Upstream O2 sensor to determine how much fuel to use. So, it acts like an electronic choke. Sometimes spraying extra fuel into the intake will help the engine start when cold. Sometimes not (can flood engine).
Another reason for long or hard start, when cold, is the fuel pump or fuel regulator doesn't hold the fuel pressure. Test would be to put a fuel pressure tester on. Crank the engine and measure the fuel pressure. Then watch the fuel pressure for about fifteen minutes to half hour. If the pressure drops quickly then the fuel is either draining thru the fuel injectors or the fuel pump or fuel pressure regulator is leaking fuel pressure. This can cause hard starts.
Noah Roberts
Jul 24, 2022 11:50 AM
Jdemery89
Aug 16, 2021 10:52 AM
Chelsey McMannis-Gaus
Nov 4, 2018 09:59 AM
phantom23
Mar 13, 2014 03:51 PM
TotalEclipseTinting
Sep 26, 2008 11:55 AM
