2002 CRV EX AWD Trouble Codes
Old Dec 29, 2019 | 02:09 PM
Shane Bianchi's Avatar
Default 2002 CRV EX AWD Trouble Codes
Check engine light on and codes P1166, P1167 and P0325 come up when I scan. I know P1166 and P1167 may mean I need to replace the oxygen sensors, correct? How easy are those to replace? And P0325 means I might need to replace the knock sensor, right? (which I wouldn't replace myself). Is it safe to drive with these issues?
Old Dec 29, 2019 | 04:17 PM
welcome to the forum. you can change a oxygen sensor if you have the proper tools and a Honda sensor. if you use an aftermarket, it may fail in a week to a month. the knock sensor can be changed if you have mechanical abilities and a service manual.
Old Dec 29, 2019 | 09:31 PM
P1166 and P1167 means there is an issue with the heater circuit of O2 sensor 1
It could be the sensor's heaters are faulty
Or it could mean that the wiring is faulty
Or it could mean there is a power and/or ground issue
P0325 is the knock sensor which has similar meaning
Part or the circuit has issues
Do some testing before replacing parts
igor2009
May 4, 2016 06:22 AM
rex_f
Dec 20, 2011 09:46 AM
logantherock
Aug 5, 2010 09:49 PM
Clay
Aug 9, 2009 11:55 AM
