2003 CRV wiring issue
Old May 19, 2019 | 09:13 AM
Spencer Wiley's Avatar
Default 2003 CRV wiring issue
So my Fiancé has had her Honda CRV for a couple years now and loves the vehicle. But as of late, she has been having some serious wiring issues, I have checked fuses over and over again and have not had any issues but currently the issues with the vehicle are as follows; Intermittent Wipers do not work (high and low setting will work and I can clean the windshield.) The drivers door power window is the only one that works. No power locks. blinkers do not work. If anyone could offer me and help it would be greatly appreciated I’m on the verge of ripping my hair out trying to figure this out. Thank you!
Old May 19, 2019 | 12:17 PM
About the power windows, on driver's master switch, is the button depressed on the master switch to disable the other windows?
If not then would try by-passing the master switch.
Sorry, don't have schematics to determine whether it needs to be open or closed to be able to operate other windows
If by-pass works then need new master switch?
Did you check all the fuses or only the ones in the engine bay?
Old May 20, 2019 | 05:50 AM
REPLY: I have checked both fuse boxes over and over can’t seem to find a issue, and any idea on how to by pass the master switch on the drivers door?
Old May 20, 2019 | 11:53 PM
You could check the what the switch does with an Ohm meter?
What position is open and closed if the switch is working?
What pin it goes to and do what it takes to operate the other windows?
If it isn't a fuse then could it be a relay?
nakedkitty15
Mar 22, 2015 08:46 PM
lciambotti
May 31, 2014 03:13 PM
tng6664
Mar 17, 2011 08:06 PM
tng6664
Feb 26, 2011 10:46 PM
skifreak
Oct 18, 2010 04:09 PM
