2007 CRV Air Conditioning Issue
Old Jul 11, 2019 | 10:56 AM
BruceRoush's Avatar
Default 2007 CRV Air Conditioning Issue
Hi All
Hope someone can help me with this issue. We have a 2007 CRV with 75k miles. Had the air conditioning compressor replaced in the past year. It works fine when we are driving along the road. But as soon as we stop for traffic, the air temp seems getting considerably warmer - not hot - but not cold like when we drive. Any ideas what may be the issue?
Thanks for your help Bruce
Old Jul 11, 2019 | 09:50 PM
welcome to the forum. the a/c fan on the radiator may not be working
Old Jul 17, 2019 | 07:59 AM
BruceRoush's Avatar
Default Thanks ACMECH
Thanks ACMECH
Old Jul 17, 2019 | 08:07 AM
BruceRoush's Avatar
Is their a switch, sensor or relay that controls the fan that I can check? I looked on the parts diagram but do not see one shown.
Thanks Bruce
Old Jul 17, 2019 | 01:13 PM
Can you apply power and ground to the fan to see if it turns on?
Usually, putting the AC on should turn on both fans on the radiator.
Do the fans turn on?
Old Aug 15, 2019 | 06:11 PM
snippy106's Avatar
Default Ac fan
You can jump the fan with a battery charger. If it doesn't come on it is bad.
Old Aug 15, 2019 | 10:42 PM
I would not recommend putting a charger on anything electrical on the car while the engine is running
There is a possibility that it can screw up the electrical system if hooked up wrong
Or to disconnect the fan (electrically) from the car and then try the charger.
Another thing to do is to inspect the condenser to see if there is any debris blocking air flow.
livelife101
Jun 6, 2018 12:53 AM
bonegrafix
May 21, 2014 02:59 PM
dlprince
Aug 27, 2008 02:47 PM
rescyth
Jun 21, 2007 12:39 AM
