2008 CR-V chatter
Old Nov 10, 2021 | 08:21 PM
npdion's Avatar
Default 2008 CR-V chatter
At speeds of 35-40mph on smooth flat road and no load to the wheels I get a chatter from the front(?)
that goes away as soon as I accelerate or slow down, that is, apply load. Car has only 75K.
Anyone have any ideas?
Old Nov 11, 2021 | 09:26 AM
You would need to do a through visual inspection of the front end.
Possible causes range from motor mounts to bolts that never bottomed out which leaves room for chatter.
Old Nov 11, 2021 | 09:43 AM
npdion's Avatar
Thanks, Avisitor.
Old Nov 11, 2021 | 11:34 AM
I know that I was not much help.
But, there is little I can see from behind keyboard.
Wish you luck.
Old Nov 11, 2021 | 12:14 PM
npdion's Avatar
Any chance it's a bad U-joint on the driveshaft???
Old Nov 11, 2021 | 02:41 PM
yes (cv joints)
Old Nov 11, 2021 | 11:55 PM
As AC mech52 said, it can be the CV joints.
But, hard to tell sitting in the driver's seat where the noise is coming from
Old Nov 12, 2021 | 12:07 AM
npdion's Avatar
Thanks again. Not being a mechanic, where are they located? Big job? Small job?
Old Nov 12, 2021 | 05:54 AM
peter2772000's Avatar
Seeing as you're not tech-inclined, you'll need a reputable shop. I suggest you find one and have them take a look.
Old Nov 12, 2021 | 09:40 AM
  #10
npdion's Avatar
Thank you, Peter.
Bazzaboy09
Aug 31, 2021 06:46 AM
Gary Born
Sep 12, 2020 07:03 PM
darwyn
Sep 7, 2020 07:06 PM
nullpointer
Dec 4, 2017 11:30 AM
davepop
Nov 8, 2008 03:23 AM
