2008 CR-V - AT - Stalls
Old Dec 3, 2017 | 03:37 PM
nullpointer's Avatar
Question 2008 CR-V - AT - Stalls
My 2008 CR-V Automatic stalls occasionally when coming to a stop at a red light. It will also stall if you pull into the driveway, and put it in park. If it doesn't stall in park, it will idle hunt (up and down up and down). The car will start right back up without any issues.
I am having trouble tracking down the issue, as I am not used to working on Hondas. I have cleaned the MAF, new plugs, checked AT fluid, did a basic vacuum leak test with carb cleaner (very basic).
Has anyone had this issue before? Tips?
Car as 120k on it.
Old Dec 4, 2017 | 01:01 AM
welcom to the forum clean your idle cut off unit. or replace it. expensive to replace.
Old Dec 4, 2017 | 08:04 AM
Would that be the same as the IAC?
Old Dec 4, 2017 | 11:30 AM
After some research, the 2008 has an eiac, so nothing to clean. Upon taking off the cover over the intake manifold, I found a damaged vacuum line heading to the PCV. Going to replace that, and perform the idle re-learn. Hoping this fixes it!
sethalross
Dec 7, 2018 03:11 PM
protohonda
Sep 7, 2012 10:55 PM
bigluelok
Jun 5, 2009 06:32 PM
ryanmcde
Oct 1, 2008 06:33 AM
jason_home
Jun 12, 2008 07:21 AM
