2012 Honda CRV Ex - Parasitic Electrical Drain
Old Jul 26, 2024 | 05:53 PM
mminten's Avatar
Default 2012 Honda CRV Ex - Parasitic Electrical Drain
I have a 2012 Honda CRV EX that has a battery that drains after not using it for a period of days.
I checked the alternator and tested the battery and they are both working.
I checked the fuses and found that it has a parasitic electrical drain on fuse 29 under the hood.
I have disconnected the hot fuses under the dash and had no change. I then disconnected the three wiring harness above them.
When I disconnect the bottom (blue) wiring harness the drain disappears.
My problem is that I can't find what this wiring harness if for so I can track the drain further. Any tips on the next step to see where the drain is coming from?
jmo2610
Jun 16, 2023 11:42 AM
timd
Jun 5, 2021 01:06 PM
Drae Drumz
May 17, 2020 02:06 PM
Kimberley Bass
Nov 22, 2019 11:44 PM
dbr1161
May 12, 2018 08:43 AM
