2013 Compass Flashing
setup button doesn't enter compass menu
Hi, I have the same "compass won't cal issue." I have a 2013 CR-V LX, and I was told it was the compass module. I just replaced it with a new factory compass module above the headliner at the rear of the vehicle (way easier than I expected BTW).
I fully expected it to work.
When I press and hold the big "setup" button, it never enters the compass cal mode. It shows the basic audio menu, so I believe the button works fine, unless there is a DIFFERENT setup button I am supposed to push.
I held the darn thing for a full minute, and it never entered. I doubt that is correct behavior.
My local Honda dealer wanted me to spend $600 replacing a compass module that cost under $100 bucks new, and took me all of 10 minutes to swap out.
Anyone see this problem? I'm hoping there is an obvious reason.
No, it didn't. I now suspect it is the "setup" button on my center console. When I press and hold the setup button, it goes straight to the standard setup menu, and does not switch to the compass menu. I'm guessing there is a defect with the actual button where it is not recognizing that it is still being held down. Now I think the original module is good, so i returned the new one until I can get that setup button working.
