2023 crv
Old Feb 19, 2025 | 03:33 PM
Hunt1's Avatar
Default 2023 crv
While driving down the road, my CRV started flashing every single light from low tire to parking assist failure. It flashes and beeps for a while then the beeping quits. I pulled over turned it off and it wouldn’t let me shut the car off unless I held the start stop button for a few extra seconds. I waited a minute and started it back up and everything was fine. I drove two or three minutes down the road, and it started up again. I stopped at an auto parts store and they checked my battery and said it had plenty of voltage and cold cranking amps. What should I try next? Thank you very much.
Old Feb 19, 2025 | 03:52 PM
Just Ducky's Avatar
Default Light Show
Not an uncommon issue in some models.
What made you think it was a battery issue?
Is your V under warranty?
What are the DTC’s?
Old Feb 19, 2025 | 07:27 PM
Hunt1's Avatar
What are the DTC’s?
There are no codes that have come up. I’ve not hooked anything up to read it yet. I thought it might be a better issue after reading a lot of replies of other CRV owners having this problem. Everything checked out OK when I had a tested underload. When I get time tomorrow, I’ll check the grounds. I just got over 30,000 miles so it’s not a warranty, but I think I might have bought an extended warranty. I have to look and see. The front end was fixed when I hit and killed another deer with it that was about a month and a half ago when it was fixed.
Old Feb 20, 2025 | 06:03 PM
Just Ducky's Avatar
Default Cornfuzion
All new Honda vehicles are covered by a 3-Year/36,000-Mile Limited Warranty, plus a 5-Year/60,000-Mile Powertrain Limited Warranty.
Is there more to your story?
Old Feb 21, 2025 | 04:34 PM
What are you retrieving codes with? Should be codes in at least one module.
Old Feb 25, 2025 | 10:03 AM
Hunt1's Avatar
The only thing they have found so far when checking the codes is a wheel sensor module. They are going to replace it, but it needs ordered and it should be in Wednesday. They are trying to program a new key fob and said there are some kind of interference happening so they can’t program right now. They have not been able to clear all of the warnings that rotate on the screen yet.
Joao
Oct 31, 2023 08:38 PM
Whaler9113
Aug 15, 2022 05:30 PM
Asphaltwarrior
Dec 3, 2017 09:16 AM
Weez1
Jun 18, 2013 11:21 AM
mcqueen
Jan 22, 2008 04:51 AM
