2024 CR-V exit memory seat setting
I have the memory seat setting where I’d like it to be when I’m driving.
Is there a way to have the seat drop down when I get out of the car? Then when I get back in and start the car it will go back to driving position. Thanks
There is a way however you will lose your two driver option.
With key fob #1 in use, set the seat at the lowered entry/exit position then program memory #1.
After mounting up, raise the seat to the desired height then program memory #2.
Before exiting, press memory #1. That will lower the seat. When you return armed with fob #1, the seat will remain lowered.
Reentry will require you to push the memory button #2.
Utilizing this work around will qualify you for the BPF club.
