2024 CR-V exit memory seat setting
Old May 10, 2024 | 08:56 PM
Tim Heally's Avatar
Default 2024 CR-V exit memory seat setting
I have the memory seat setting where I’d like it to be when I’m driving.
Is there a way to have the seat drop down when I get out of the car? Then when I get back in and start the car it will go back to driving position. Thanks
Old May 11, 2024 | 03:21 PM
Just Ducky's Avatar
Default Fobbing
There is a way however you will lose your two driver option.
With key fob #1 in use, set the seat at the lowered entry/exit position then program memory #1.
After mounting up, raise the seat to the desired height then program memory #2.
Before exiting, press memory #1. That will lower the seat. When you return armed with fob #1, the seat will remain lowered.
Reentry will require you to push the memory button #2.
Utilizing this work around will qualify you for the BPF club.
GMS2
Jan 26, 2025 09:12 AM
monarchmom
Oct 21, 2023 11:41 PM
HarlisHonda2000
Apr 5, 2022 03:54 AM
geno368
Jul 18, 2021 10:23 AM
MagicOPromotion
Jun 18, 2009 06:26 AM
