'98 crv: instructions for interior disassembly
Old Apr 27, 2021 | 12:17 PM
  #11
thook44's Avatar
Originally Posted by avisitor
That is great. Found the leak. Now it is time to fix it!!! Yay.
indeed....thanks!!
Old Apr 27, 2021 | 05:46 PM
  #12
vroomvroom593's Avatar
Originally Posted by Rhonda
You checked the drain channel but did you check the drain tubes on each side to make certain the drain channel moisture is actually flowing out of the car?
At this point, I honestly don't know if checking the drain tubes on each side of the car would make any significant difference.
Old Apr 27, 2021 | 07:20 PM
  #13
thook44's Avatar
it appears my leak has been coming through the hole behind the fender where the hood release cable runs. as i recall, the previous owner/my friend had the cable replaced several years ago. so, whoever did the job didn't reinstall the boot seal the cable runs through. it was pushed in through the hole to the inside leaving a nickel sized opening for any rain draining from the cowl to just pour right into the cab. <<sigh>>. the boot seal is still in great shape, so i reinstalled it and, for good measure, ran a bead of polyurethane around it. rain coming in late tonight through tomorrow. test run coming up
btw, there are no drain tubes whatsoever on this thing. just some molded sheet metal acting as a channel. and, no...it wasn't clogged
Old Apr 27, 2021 | 08:03 PM
  #14
Thank You for the feed back.
Old Apr 27, 2021 | 08:27 PM
  #15
thook44's Avatar
sure thing. i'm aware of the importance for others' searching for answers in the future. and, tbh, i had not run across this hole being a culprit in any of mine. it was easy enough discovery, though
Old Apr 28, 2021 | 01:21 PM
  #16
thook44's Avatar
it's been raining since before dawn and no leaks. problem solved . i still need to get trim off and carpeting up. i think i'll do a write up in case anyone else searching the web needs it.
Old Apr 28, 2021 | 07:31 PM
  #17
Where is the "like" button??
Porkupine
Oct 25, 2019 08:03 PM
Valhalla
Jun 15, 2019 08:11 PM
jovo14
Jun 28, 2013 08:38 AM
snookjohn
Mar 30, 2011 07:41 AM
veloman
Apr 30, 2009 03:26 AM
